Lakesailor
Anyone had a problem like this?
I am helping someone rebuild his Petter AC1W in a Snapdragon yacht.
After asking me advice about non-starting I suggested it sounded like his engine needed a re-bore. He stripped it and took the head and barrel to a local guy I know. He pronounced it all-but dead. However he refurbished the head, and suggested he had the barrel re-bored, Which was done to +0.030" by a specialist firm in Lancaster who supplied the new piston.
He bought the gasket set from ebay from a Petter specialist. They are genuine gaskets.
It's a bit complex fitting as you have to measure the squish gap (bump clearance) in above the piston and adjust it by use of shims beneath the cylinder barrel.
So we fitted the new piston and put the shim on the crankcase then the barrel onto the piston. Assembling the head with new gasket we used soldering wire to compress into the squish area and then removed the head to measure the solder's finished thickness.
This led us to remove the shim, before reassembling the head and connecting everything up.
The engine started and ran well, but water pissed out of the block/head joint.
We took the head off and the firing ring (the metal bit around the bore, which is supposed to compress, was not very compressed and still 0.010" above the gasket material. This meant the gasket material was not sealing the water passages.
The head nuts are only supposed to be tightened to 20 lbs/ft, which we did with a torque wrench. We decided to clean up and lubricate the stud threads and face up the washers and nuts so that nothing was distorting the torque figure. I called a friend who is very good motor engineer who suggested maybe going up to 24 or 25 lb/ft.
We re-assembled it and started the engine. Nothing had changed. A jet of water peeing out. Stripped it again and the firing ring had not compressed any further (0.055" as opposed to the original gasket which measured 0.039") There have been different thickness gaskets over the years but they have presumably matched the firing ring thickness to the surround material.
My friend then called the engineers who supplied the gasket set and the guy he spoke to said that he had an engine in the workshop with the same problem and we had solved the issue by finding this. He told us who he got the gaskets from (Lister Petter) and their phone number. They weren't particularly interested. "We sell half a dozen a week and no-one has reported problems".
Hmm. Well now 2 people have. Obviously a rogue set of gaskets.
Anyone had similar problems?
New gasket
Old Gasket
Cylinder top
Old Gasket
Cylinder top
