wipe_out
Hi all,
When we bought the boat we were told that the previous owner had had an access hole cut into the fuel tank in order to clean out contaminated fuel but it was all professionally done and fixed..
When I looked at what I could see of the work (it's under the aft berth floor so could only just see it from the engine bay) it looks pretty solid with stainless steel plate bolted to the plastic tank..
https://drive.google.com/file/d/0B0KuiZvmbiCxSDY1VTNLWlpWY1U/edit?usp=sharing
Anyway, we haven't had a problem with it until now.. I filled the tank right to the top over the weekend and now there is petrol in the bilge.. I have checked all the hoses and obvious places and they all see dry so I suspect the pressure of the full tank caused this to leak..
Plan is now to reopen the floor in the aft berth and check it and if its leaking to seal it..
Question is what options are there for sealant that is able to be immersed in petrol??
Or are there any other ideas to make sure it's a good, permanent, seal?
