Perspex
stretch33
20 Jan 2002
Essex
Anyone know where l can find a supplier to have wash boards cut around the East Coast, got to be fairly robust, think current wooden boards are two 12mm ply glued together.
Cheers Phil
Mudplugger
12 Jun 2003
East Coast/ North Sea
Phil, There's a sign Company on the industrial Estate as you go out of Colchester on the Maldon Road that used to supply Perspex etc. The Owner was a yachtie till he took up Flying....but I can't remember Name....Put it down to a Wogan moment.
Regards Tony W.
<hr width=100% size=1>Tony W.
VicS
13 Jul 2002
Precision plastics, Colchester. Located at the back of an industial estate off what was many years ago the by-pass, not a million miles from the station. If they are still there.
<hr width=100% size=1><font color=purple>Ne te confundant illegitimi.</font color=purple>
wishbone
20 Jan 2002
South Yorkshire
www.reflect-designs.co.uk
I should try a local sign co. you should be able to get some polycarb offcuts, will be a lot cheaper than a full or part sheet!
<hr width=100% size=1>Wishbone
Rolling, rolling, rolling keep them doggies moving!
Where’s me chuck wagon gone?
bob26
21 Dec 2002
Sussex-by-the-sea
www.tridentlottie.com
Are you contemplating 24mm of perspex? My guess is that would be rather heavy and expensive and virtually impossible to find. If its to fit a channel that thickness, have you thought about thinner perspex in thicker edging (wood or strips of perspex stuck to the edge?)
halcyon
20 Apr 2002
Cornwall
Polycarbinate, i.e Lexan, is a better a better option than Perspex. If you hit perspex it has a tendancy to shatter, with Polycarb you can hit it with a hammer without damage, material they laminate to make bullet proof glass. It's about the same price, and machines a lot easier.
Brian
Talbot
23 Aug 2003
Brighton, UK
Whilst what you say is correct, it is also fair to say that polycarbonate is much more prone to scratching than perspex.
