Dino
I have a pair of Perkins Sabre M265Ti’s in a Broom Ocean 38.
I am having intermittent stern gland cooling issues and the telltale is pulsing at tickover?
When at tickover speed my starboard engine doesn’t have a steady flow of water like the port engine, it pulses. It turns to a steady stream when I increase revs.
On 3 or 4 occasions over the last year I have had an overheating stern gland with a load rubbing noise. Each time I put the engine in neutral and ran on the other engine.
My M265Ti’s have a water feed off the front face of the heat exchanger, through a reinforced pipe to the stern gland.
I have descaled the raw water circuit with Wessex Proflush, replaced the impeller, cleaned the strainer before the impeller, checked both ends of the heat exchanger, descaled the raw water intake and perforated tube and replaced the pipe to the stern gland.
When I remove the pipe from the stern gland with the engine running there is a steady stream of water but if I put my hand to the end of the pipe there is no real pressure. I’m guessing that by putting my hand over the pipe I am diverting water down to the exhaust telltale.
Should I put Descaler into the stern gland?
It seems like the water is taking the path of least resistance and flowing out the telltale as the pipe in the stern gland is pretty small.
Has anyone resolved this issue?
