lyleknab
New Member
Hi,
I have a Perkins Perama M30 (which is also identical to a Volvo MD2030) having problem of low revs while in gear runs perfectly in neutral with plenty of revs.
Problem first appeared after changing fuel filters but this may be co-incidence.
I suspect being caused by lack of fuel getting to the injectors but have tried various things with no success and I have now run out of ideas, hoping someone
can offer some more advice/suggestions.
What I have tried so far:
Shaft spins freely with hand when in neutral
Checked exhaust elbow for blockage - completely clear
Swapped lift pump (because I happened to have a spare) although the lift pump was new a year ago and seemed OK.
Bled the system several times.
Removed the fuel filters to check for twisted gaskets or any corrosion where gaskets sit.
Installed another set of filters (just to be sure)
Put a clear plastic pipe on the fuel return line to check if there was air bubbles in the return and guess what absolutely no fuel going through the return either running full speed in neutral or as fast as it can go in gear..
So, that makes me think the problem is lack of fuel.
Disconnected the output pipe from the primary filter and put it in a bottle of clean diesel to try and rule out any problems with fuel tank, pipe from fuel tank and primary filter. No change in the symptoms with fuel being fed from bottle of diesel.
Replaced all copper crush washers on banjo fittings.
One thing I notice when I operate the lift pump manually I cannot get fuel to squirt out at the various bleed points (although it squirts when engine is turned over)
Could I have 2 x faulty lift pumps - seems unlikely. With lift pump removed and operate it by pushing on the buttom pluger get plenty of suction when put finger over the IN.
If I crack open each injector in turn engine slow down so assume each injector if operating OK (injectors were refurbished by Perkins dealer last year)
Think I am out of ideas now - help please
