Gerry
I am confused by conflicting advice. This engine has no integral anode and has a negative earth relay, so I suppose it should be isolated from the earth/grounding anode. Yet mine is grounded to the negative anode. Is this right or wrong?
Other than the engine wiring harness, what other connections should there be to the engine (alternator, starting motor, etc)?
What will happern if the negative earth remains?
