SJHE
The temperature alarm on my 6354 has decided to turn itself on permanently despite the gauge reading the normal 80 degrees C and everything else appearing to be OK (coolant level steady, sea strainer clear, raw water pumping well etc).
Is there any way of testing the sender with a multimeter to determine if it is faulty and is there anything else that should be checked as a possible cause?
If it is the sender unit, can anyone advise on the best way of removing it without breaking it off as it looks well painted and corroded in!
