Perkins 6354 - Fuel Consumption?
Jim@sea
12 Feb 2010
Glasson Dock
All these Perkins engines were used in Massy Ferguson Tractors and if I was trying to find out gallons per hour and it wasent readily available I would try and look up Tractor informatopn. Certainly buy any engine spares from a Tractor dealer
Greg2
24 Jun 2002
We used to have a semi-displacement Broom Ocean 37 with these engines and used to cruise at 10 knots when we used 4.5 gallons per hour for both engines if my memory serves.
moonraker 36
20 Aug 2009
no idea what gph (have a pair of 175shp)in the moonraker.unless run flat out i find very good on fuel.
i just fill up when the tank needs it.!
Greg2
24 Jun 2002
Are they turbo or NA?
If turbo, then at 1800 revs you'll burn about 2.5 gallons an hour each.
No idea about NA.
Ours were the turbo version and the 4.5 gph we recorded would have included some displacement speed cruising in rivers at each end of a sea passage so 5 gph for the pair at 12 knots sounds about right.
Firefly625
18 Mar 2009
Home=Surrey / Boat=Hamble
Latestarter1
6 Feb 2008
Somerset
Turbo and I am told rated a 220hp each which seems higher than other engines quoted.
You need to provide a heap more infomation.
Max rating of T6.354 was 175 (150) Hp.
T6.354.4 went to higher power ratings 200 (185Hp) being one. However these were significantly different engines from those quoted. Range 4's had watercooled Holset H1 turbochargers and the dreaded 'Manicooler' set up.
l'escargot
Isle of Wight / Jersey
Getting it in bits and pieces does T6354M add anything?
Latestarter1
6 Feb 2008
Somerset
Absolutely ziltch!
Engine serial # on machined block face at base of fuel pump.
Some simple ways to spot a Dot 4 are;
Alloy not tin rocker cover.
Viscious not bonded crank damper
Water cooled Holset H1 turbo, not dry 3LD
Socking big combined manifold heat exchanger 'Manicooler' instead of simple wet manifold.
Oh and fewer oil leaks.
The Dot4 esn# should start TU,V,W,X etc in example format TU6.354.4UXXXX
l'escargot
Absolutely ziltch!
Well they certainly looked clean without oil leaks. Should get a closer look at them and some more info this week. Thanks.
epervier
16 Dec 2005
Still....very close to the Solent
At cruise 1600/1800 rpm 6 gallons per hour for both donks, as always depends on how lumpy it is out there, I can give a more accurate guesstimate later in the week when I bunker again, I've logged my running times yesterday and today so I'll be able to give a closer number, if you're interested.
