D
Deleted member 36384
Hi,
My Rival is now launched after 2 1/2 years ashore. The engine started fine and has had a very long run, so all appears to be well.
After the long run the water from the hot water tank (calorifer) got very hot, hotter than I remember. The water is heated via a standard Perkins M90 heat exchanger. I have two hot water tanks, an electric immersion heater tank and the calorifier, both are connected to the pressurised water system. During the partial refit I removed the insulation around the calorifier because the insulation was damaged and contaminated with oily water residues, it was just loose wrap type insulation. The insulation has not been replaced. The only other change to the water system was new accumulator tank and bladder. The pressurised system works well.
When I went through my pre engine checks, the fresh water coolant in the header tank was lost but the engine still had plenty of coolant. So I topped that up.
I don't have my manuals at home with me but I am wondering if there is a thermostat in the hot water heat exchanger and if it has stuck in the open position. Also do you think the lack of insulation would cause the circulating water from the calorifer to continually circulate and end up very hot.
The engine temperature gauge was a stead 80 degrees celsius on the long run. Of course, my recollection may be wrong and I have always had water that is very hot.
Any thoughts would be appreciated.
BlowingOldBoots
BlowingOldBoots
