Petercatterall
Last season it was the (enclosed) solanoid (that always failed at critical moments!)
I asked the local marine electrician to fix it and got a bill for £560.
A year later (maximum of 100 starts!) and its gone again! This time the starter was spinning but not engaging. Checked battery and connections, all good.
Not having £500 to spare again I set to and removed the starter, had to drain oil, remove filter and an oil hose but not difficult (especially as the bottom fixing bolt was missing!!)
The gear end of the starter looked quite 'manky', when tested the gear only span out about half the length of the shaft (possibly not enough to engage the engine gear ring?)
With mirror and torch I had a look at the engine gear teeth, I was conerned to see bright shiny steel on two of the teeth but, getting my hand in, they did not feel chipped or worn and I guessed that they may have just been polished by the non engaging starter gear teeth.
Took the unit to a local auto electrician, first comment was " cor what a mess, has it been near water"?
Questions to the experts
Should the starter gear fly right down the shaft to engage?
Is using 2 bolts rather than 3 acceptable? ( Iguess that having locted the unit with the top (accesable) bolts I could get the bottom one in with a long extension mirror and torch!!
Should there be some sort of seal between the starter and engine? could the hole of the missing bolt have allowed splashed up bilge water in?
The electrician recognised the starter as being originally a CA45F, he says that he will have to source some bits and pieces because of corrosion but is confident that it can be rebuilt for £50/75 What was my bill of £560 last year for??
Any hints or tips gratefully received
Regards to all
Regards to all
