pcatterall
Looks like the new starter has not survived its sinking!! No amount of fresh water bathing and drying seems to free up the shaft. The local auto electrician says that being the inertia type ( rather than pre engaged?) and having the solanoid in the nose makes it more complicated and easier to suffer in bad conditions. He claims to have a bracket that will enable me to fit a pre engaged more robust starter, are there any thoughts on this please??
What have you other guys got fitted ? The existing starter is a bit long so that I have to remove the oil filter and the oil pipes to get it in and out, a shorter unit with the solonoid on top would be easier to get in and out.
It is getting to the stage when I am concerned about shutting off the engine in case the starter wont go.. not much comfort when you are out for a sail!!
