Biscay 36
Instructions say it is attached by three set screws with allen key heads. Mine had one bolt and two nuts onto in situ studs. I can replace the top two for the recommended screws and they will be much easier to get at and adjust but there is just no space at the bottom postion to use an allen key on the screw. I had a real struggle freeing off the original nut and refitting it will be very tricky. Any ideas out there? Just as an aside the engine is having a new piston fitted by the local mechanic after a disasterrous ingress of water caused by a dribbling cooling water seacock. Three of them carried it off the boat moored bows on to the pontoon! It's in Brazil.
