l'escargot
Had intermittent starter problems on my 4107 - low cranking speeds similar to low battery power or bad earth. Checked all wiring to battery and solenoid etc. and re did earths. Battery borderline so renewed battery. Problem continued so took out starter and stripped it down to find that the insides, commutator, brushes etc all smeared with copious amounts of grease - it would appear that previous owner thought it all looked dry so "remedied" the situation!
All washed down with petrol, dried off and reassembled.
No problem for a while until yesterday. Switched off engine whilst hot, went to restart a short while later but engine barely turned over - voltage OK in battery. Left for half hour then restarted OK and has done several times since.
Now where do I go?
1 Accept it as a glitch and ignore until it happens (or not) again - possibly after a sail and engine needed.
2 Strip down starter motor again and give it a good clean up as I may have not done as thorough a job as needed last time.
3 Look at other options - maybe solenoid.
4 Splash out on new starter.
Now where do I go?
