coopec
N/A
The Perkins 4-108 is rated at 51 hp at 4000 rpm (intermittent) and 39 hp at 3000 rpm (continuous).
I really don't want to run the motor at that speed so I was thinking I'd cruise at around 2000- 2400 rpm. Maybe that is a mistake? (The expert who supplied the propeller worked on 3000 rpm cruising)
I am in the middle of installing a 24V 60A alternator and have found I can bolt a duplex "V" belt pulley to the existing (5½ in. diam) pulley on the crankshaft. (There are 3 holes already machined into the pulley). The existing (single V) pulley would be retained to work the water pump (I'll have to make up a tensioner)
Now the question is what diameter Duplex pulley should I bolt to the crank shaft pulley?
The existing ratio of crank shaft pulley to alternator pulley is 5½ in. to 3½: Should I maintain the same ratio with the 24V alternator?
It just so happens that the 12V alternator has the same diameter pulley as the 24V pulley so do I bolt a 5½ in duplex pulley to the existing crankshaft pulley?
Would there be any advantage in going bigger/smaller? Can anyone please advise?
Clive
Clive
