danielefua
I have a small diesel leak on the main fuel pump where the anti-stall device is placed. The device is actually screwed into an aluminum plug which can be easily taken off because it is simply pushed into a bore in the upper part of the pump body. The diesel pump is probably a DPA hydraulic type but I am not sure because I am not able to find any positive information neither in the Perkins workshop manual nor in the net. My questions are:
1) which is the recommended way to fix the plug in its bore.
2) where can I find a new anti-stall assembly or, at least, the gaskets and the top screw.
Thank you for your help
Daniel
Daniel
