huldah
Hi, during removal of heat exchanger, the bolt on the rear end broke .I have successfully drilled out the old bolt leaving a thin layer of metal in the thread inside. I need to identify the thread so I can clean out the old metal. The OD is approximately 7.9mm. It has approximately 21 threads per inch. I assume this to be an American thread. Presumably these taps are still available, if so, where do I obtain them?
