Gypsy
In response to a previous post I mentioned that I was disappointed with my Pela 6000 whilst others gave it plenty of credit.
It was my first use and I obviously made a few mistakes, but today it paid for itself in one go.
One benefit of changing the engine filters oneself is that you see what crud has gathered and hence the filter doing its job. I was surprised and alarmed at the amount of water in the pre-filter and even some in the filter after the pump. Alarmed enough to decide to try to drain the water at the bottom of the fuel tank.
Bring the Pela back in from "the cold". The narrow "anteater" bowden cable snout allowed me to probe down the side of a partially released fuel guage to get to the lowest corner of the tank. A quick "suck" and a bit further poking with the snout and I was able to remove about 500ml of water plus some physical crud.
It is 5 yrs accumulation so I guess that is not too bad, but a very satisfying result. I decided to install a Racor pre-filter with a transparent bowl to help me see the water buildup in future.
I have also trimmed the "anteater" snout to the maximum necessary to get to the bottom of the engine sump and the fuel tank to reduce the resistance for future oil removal so I expect I will certainly get good use out of the Pela....it can stay on the boat.
