pegging a wheel
suse
Cambridge
I used to tie off (quick release) the tiller in an earlier boat, as a rudimentary autohelm, and for short spells and a steady wind, this was fine. Now with wheel steering and no autohelm, I have resisted the temptation to lock off the wheel while sailing, in case a wind change caused either steering breakage of some sort, or a sailing accident of some sort - neither of which I fancy!
Without buying an autohelm/windvane, etc, is there any way of fixing the wheel for short absences? With a v quick release system? Or do I just continue as usual, making quick dashes? (She holds her way beautifully and keeps well balanced, despite my sail trimming! - long keel - so the 'look no hands' option can be pretty good).
Thanks for advice.
This means my rudder is fixed, as solidly as I can tighten the wheel lock - is it still OK?
signed, nervous
What about a bungee hooked onto bottom spoke of your wheel around the binnacle mount and hook back onto the same spoke...............just a thought
<hr width=100% size=1>Dave
I use the wheel brake all the time when going to windward as the boat is a much better judge at which course to steer ( incl. windshifts) than the Autohelm.
She will track perfectly for hours and I've never seen anything going wrong with that method
J.
