Steersman
Active Member
Out now in the August edition
Thought it looked a bit 'Heath Robinson' and intrusive compared with vanes and autopilots.
Also, not clear from the article how (or if) it would work with a wheel.
Looking at the site, he has at least made a slight improvement since last time. You no longer need to remove your primary winches and mount them on top of the contraption, instead the contraption can be placed on the coaming behind the winch and the sheet passed through a cheek block (I hope it's also a snatch block) when you want the contraption engaged.
The version in PBO has the winches relocated on top of the 'platform' while the platform seems to be mounted about where the original winches would have been.
Yes, that's the original version that he's been touting for years and has installed on his own boat.
I'm slightly surprised that he hasn't come back to this thread since posting it. Usually he sticks around to try to justify why the contraption is worth buying. Perhaps this time he just wanted a standalone advert.
Sounds like the engineering is sorted out, but from my point-of-view what it desperately needs is a good Product Designer to make it look desirable and a lot less clunky.
Somewhat doubt if looks are much to do with it. If anything, a windvane on the back speaks of distant shores.Hi Ken
In terms of looks, I think it often comes down to what you're used to. For me, I can't understand why anyone would want a windvane hanging off the back end of a boat. It's not only vulnerable to damage, but looks plumb ugly. At least with the Steersman it's a lot smaller and as such, is not as visible. Also I have taken a lot of time in the styling of the new models, and I think they look a lot more acceptable. Also, if you look in PBO magazine and see Justine sailing along, you have to know what to look for in order to spot the Steersman. Compared with a windvane, I think the Steersman is pretty unobtrusive.
Around the Solent, a wind vane is posing tackle, look at me, serious offshore sailor.Hi Ken
I'd like an autopilot that could work well, while using a lot less power.
Maybe electronics for sensing, but power from the sails or sea for steering.
And it needs to work with at least a cruisng chute, to me the point of autpilots is to free up the sailor to do things like put more sail.
I'm used to not being a target market.
