mlines
Nothing more than a 5 minute dip in a bucket of Wickes Patio and Brick cleaner
I'm not sure I'd risk it on a brass/bronze prop.
Why? Nothing that is in brick cleaner will have the slightest effect on a bronze (or brass) prop except dissolve any deposits just as it cleans muck off bricks. Commonly used to clean props of that type in exactly the same way as the example given.
And on kettles,drinking glass`sAlso works on false teeth
(dentist thought I should pay £20+ for a professional clean)
Brick cleaner that is dilute Hydrochloric Acid will dissolve bronze nicely given a foothold. http://nautarch.tamu.edu/CRL/conservationmanual/File12.htm
Stainless Steel and Hcl ..... http://www.bssa.org.uk/topics.php?article=30
Brick cleaner that is dilute Hydrochloric Acid will dissolve bronze nicely given a foothold. http://nautarch.tamu.edu/CRL/conser...n hydrochloric for quite such a time scale ;)
Patio magic ????I always use Patio Magic to clean my stainless shafts and rudders, bronze props, and dribble it through all four cutlass bearings. When the fouling has gone then wash with fresh water. It works a treat.
j
What I really fancy is something to clean my prop without a liftout. Perhaps I could infiltrate some HCl around it by pouring some into a tube that ends nearby, with a funnel of course. To hell with the wildlife - I want to go faster. Please don't take this seriously.
you could do it electrolytically.
completely isolate your engine and transmission electrically
connect the positive terminal of your battery to the prop shaft connect the negative terminal to a chunk of copper brass or bronze ... an old pro will do. Actually an old anode would do. Lower it into the water near your prop. 'Please dont take this seriously.
Well just had my local diver clean my prop and shaft for 100 ZAR about 5 Quid in UK money.... an old pro will do May take some persuading but I suppose for the right money........
