Gordonmc
It was not the best start to the weekend.
After driving two hours to the mooring after work on Friday I got to the loch-side and found my Avon Rover had been slashed, along with three others.
Each has a clean cut, about a foot long in one chamber. On mine the cut went through the seam between the sponson and the cone.
It was too late to do anothing other than find a hotel for the night and get a lift out to the mooring the following morning. Fortunately I had a second inflatable on the deck.
I will have a go at a repair, but because of the seam I think it will need an internal patch as well as a standard patch on the outside.
I have a bit of hypalon which should be big enough for both... but I would like advice from anyone who has fixed a chamber with an internal patch.
I am thinking along the lines of cleaning the inside of the "wound" with tuolene and applying two-pack adhesive to the patch only. With plenty of talc thrown around inside I should be able to get the patch inside by rolling it, then pressing the closed wound onto it.
The outside patch would be done as normal with contact adhesive on both surfaces, allowed to tack-off.
Anyone have any thoughts?
