laika
7 years ago I was pretty handy at epoxy repairs. Not having done anything for years my mind is blank so I’d like a sanity check. Last time I did some extensive blister repair to my rudder “properly”. I have some small blisters I’ve ground out, little time out of the water and would like advice/sanity check on the quick and adequate approach . I don’t want to scrape all the anti foul off the rudder. I plan on filling the ground out (small) blisters using silica thickened epoxy, grinding smooth, then coating with epoxy primer before anti fouling. Last time I think I used 2 coats of hemple primer and one of primocon. I’m wondering if I can get away with one coat applied with a foam brush to avoid stripping large areas of anti foul around the repair as would seem to be required for the “good” approach with a roller.
