Passerelle deck fitting
rigpigpaul
5 Aug 2004
Merseyside & Yalikavak
Hi All, my paserelle has a 20mm diameter pin at the end which locates into a 80mm diameter flange type deck fitting with a 22mm sealed tube. This is located on the bathing platform. I want to add another deck fitting at a higher level at the back of the cockpit. I have recently been stern to on some high town quays. What is the correct name of the deck fitting and where could I buy one from. Thanks in anticipation RPP
Just called pasarelle sockets - but you will need to find who made the unit to buy a spare socket or have one fabricated. The only one that is sold in this country AFAIK is the Trem one that is available from Force4, but the pin for that is 25mm.
An inset one is easy for an SS fabricator to make as it is just a tube and a flange. If you are mounting it on the transom you will need a substantial bracket, through bolted with a big backing plate inside.
