wragges
Hi All,
Anyone know what symptoms to expect in diagnosis of a partially blocked exhaust (elbow).
I have a Volvo 2003 that revs fine when out of gear (3200+rpm), but will only get to 2100 rpm in-gear. I originally suspected the prop, but this appears to be original and correct size for the boat.
The only tell-tails I have observed are: anti-syphon is a emitting a little more continuous flow than I would expect as "normal", and also the engine is very sluggish to start the first time each day...takes 20-30 seconds of turning over (and yes I do know the correct cold-start procedure).
No smoke to speak of (either hot/cold black/white). Good (but intermittant flow of water from exaust).
Have changed both fuel filters, given it nice clean/fresh diesel, Soltron etc. not sure what else is worth checking...am sort of thinking it might be the exhaust elbow but no real clues...any advice appreciated.
Cheers,
Cheers,
