Part number for Fordson water pump
SweenyTodd
New Member
3 Jan 2018
Good morning all
This is my first post and I have been pointed in the direction of this forum in the hope that you can identify the correct part number for a replacement water pump for my boat engine. The engine is a Fordson with a parsons pike conversion. The engine serial number is 2701E-6050. I am struggling to find the correct part to order so any help would be gratefully appreciated.
Thanks in advance
Welcome to the forum
The number you give is not the serial number but just the part number of the cylinder block casting.
However, a 2701E series engine is not a Fordson (that name was only used on much earlier tractor parts) but a straightforward Ford truck engine. You do not say if it is the seawater or freshwater pump - the former will likely be a Ford part and the latter probably a Jabsco or Johnson and fitted by the mariniser.
Suggest you try Lancing Marine as they are specialists in marine conversions of automotive engines.
Thanks for your reply Tranona.
I will try Lancing Marine. Its a freshwater pump. I have photos but no idea how to post them here.
