superboots
I have a VP TMD 22P with the standard panel. The ignition light does not go out on start up or with higher revs. The alternator has been checked and is charging. Any ideas how to find the cause appreciated.
With the engine running both sides of the bulb should be 'high' so no current flows.
Measure the voltage at the WL terminal of the alt. It should be 14 or so. (engine running).
This goes to the bulb. If the other side of the bulb is low, causing the bulb to light, the fault is on the low side of the bulb.
THis is where boats differ from cars, the bulb will often have circuits hanging off it to run a buzzer. This may include diodes.
This varies from engine maker to engine maker, is sometimes messed about with by boatbuilders and owners.
So it's hard to decypher over the forum.
Is there a bleeper and is it bleeping?
You might try removing the wire from the alt and replacing with a simple 2W or so bulb (not LED) to +12V as a test.
When you say 'it is charging', I'd ask if it's putting out the current it should? Do the volts drop if you put a load on it like a couple of headlamp bulbs or any handy load that will pull several amps?
With the engine stopped, removing the wire from the WL terminal of the alt should cause the bulb to go out.
If it stays on, there a fault and it's not in the alternator.
HTH?
This is digging 40 years into the memory banks but a modern alternator has 9 diodes. Three of which are to do with supplying balancing voltage. When you switch on the voltage is unbalanced and the warning light is on. Once the alternator is turning it supplies a balancing voltage and the warning light goes out.
I think you may have one or more of these diodes going / gone bad.
NB the alternator still charges normally using the other 6 diodes.
Do you by any chance have multiple batteries and a battery isolator unit that manages the charging? I had exactly the same problem when I bought my boat and I isolated the problem to be caused by the battery isolator between the alternator and batteries, incapable of registering the approprriate signal back to the engine.
Try bypassing your isolator and connect your alternator directly to the battery and see if the light goes off. If it does then you have found the cause.
