Pair of very smokey AD41's.....
dpb
14 Feb 2007
Poole, Dorset
The boat, which belongs to a freind, is a 30ft flybridge (gibsea gibralter) on shafts, about 1990.
Upto 1800rpm all fairly normal.
The videos show what happens from 1800rpm to about 2900rpm.
Temps and oil pressure about right.
Turbos can be finger turned.
Injectors have been serviced and intercoolers checked.
I am thinking turbos are the problem.
The bottom is dirty for sure, 2 years since scrub, but is that capable of causing this?
Not sure if clear in vids but what looks like globules of black oil emitted in with the smoke.
Anyone had similar and found solution.
Portofino
10 Apr 2011
Boat- Western Med
Where’s Porto and EGT’s when you need him 😂
Just catching up .Yup the fouled hull is the culprit.
If you had EGT deltas or load …….It’s mega overloaded .
Continued usage like this will as Vas said destroy the engines , the excessive heat burns the injector tips = hose = melt pistons .
NBs
9 Nov 2017
Hi,
maybe the green transition is a good thing!
The smoke is as if the boat is heavily over propped, so bottom maintenance could really be the reason.
There may be other reasons, but turn over this card first.
NBs
colhel
9 Jan 2011
Gillingham(Dorset) Boat Weymuff
If it's on shafts wouldn't it be tamd41 engines? I had a problem with black smoke which was cured with a bottom scrub but I'm sure it wasn't as bad as that. Just another thought, is max revs at WOT being achieved (3900?), are the props correct? Are the trim tabs stuck?
dpb
14 Feb 2007
Poole, Dorset
Wot is 2900 at the moment.
Props assumed original.
Trim tabs work ok and dont make much difference.
Have not tried reving over 3000rpm in dock.
My friend is arranging for boat to be lifted.
Will update this post with progress.
