Kelpie
So, the new (to us) boat has arrived. First job is a lift and hold next week to get the stuck centreboard swinging as it should, and to apply the necessary primers/AF to the various underwater surfaces.
The hull is GRP so no worries there, the bolted on keel is lead which is new to me- I guess a good compatible primer is my friend there.
The tricky part is the centreboard. The seller told me it was bronze, but documents with the boat suggest that it may be galvanised steel.
I have been in touch with the owner of the same type of boat, and was relieved to hear that fouling on the centreboard was minimal, presumably due to the absence of light when it is retracted into the slot. However it seems sensible to put some sort of AF on there.
The problem is finding a primer and AF that are compatible with these metals- very few brands mention bronze, and the tins of AF I have already got are not compatible with galvanised steel. Will a good barrier coat allow me to put whatever I want over the top, or is that asking for trouble?
