FairweatherDave
I have searched various threads on painting aluminium and I am still confused. I am "restoring" my Centaur portlights and there is some corrosion in places. However I have parts of aluminium which seem pretty good. I am not sure what anodised means technically but I presume the good bits are where the anodising has remained intact. Should I do a thorough rub down/plus boiling water then use etching primer and paint all the aluminium, internal and exterior surfaces OR should I only paint the internal aluminium and leave the external bits to the elements? Does a "thorough rub down" damage the anodising on the significant areas that have not corroded?
I want to hand paint/do the job as cheaply as possible but paint recommendations would be useful. I have the etching primer ((U-pol Acid #8) but was shocked at the price of hammerite (smooth) and enamel so thought I'd get advice here. Many thanks for any contributions.
