2ply
Active Member
I've got a (16ft) plywood skinned runabout, and want to epoxy paint the hull. Old paint is falling off in sheets and taking the smooth surface of the ply with it - leaving a sort of roughened 'graining' behind. Should I try and sand this surface perfectly smooth before painting, or should I use some sort of epoxy 'filler coating' that can be sanded fair before topcoats? (I'm thinking a filler coat might stick better to the slightly grainy surface.) If so, is the filler coat something that can be bought off the shelf, or will it involve self-mixing microballoons(?) with something else... if so what? Thanks for any practical advice – I'm a novice with 2 part epoxy paints/fillers and such.
