Paint deck, before or after removing and rebedding hardware?
steve yates
16 Oct 2014
Benfleet, Essex/Keswick, Cumbria
It occurs to me that while all my headlining is stripped off, and before I make attempts at replacing it with something else entirely, it might be a good idea to remove and rebed all the deck fittings. The decks are also going to be reappointed. Does it make any difference if I repaint first or last! Or is best practise to remove everything, repaint, then rebed?
Mostly you are going to repaint more often than you remove the fittings.
Are we talking ordinary GRP deck and anti-slip paint?
You don't want to mark the new paint with sealant, or by clonking it with tools or even walking on it while the paint is still soft.
You don't want lots of holes open while you wait for the paint to dry.
Paint under the fittings if you need to. Get the fittings on, mask them and paint the deck.
Some people paint the deck afloat, to avoid grubby footprints from the yard.
steve, you will have fun removing all deck fittings on your Westerly as all the nuts were glassfibred over in the factory to prevent water ingress. So, you only need to reseal any deck fittings that have been fitted or changed.
Remove, paint and rebed.
No option in my mind, if you're going to do it, do it properly, everything should come off, that's exactly what I did,
However, I did one area each side at a time, cockpit, coachroof, foredeck and sidedecks, initially removed each fitting, painted a couple of coats of deck paint around it (I used Premier deck paint, a tin of white and a tin of grey mixed got me the right pale grey colour), then plugged all the holes with blobs of sealant while the paint dried and subsequently rebedded the fitting - the whole task was done over several days of fine weather, when the rebedding was completed I finished the whole deck area.
Don't know Westerly's but if your sidedecks are in sections like mine I masked them with square corners then traced around a suitable size bottle cap at each corner with a sharp Stanley knife blade to make every corner identical.
As was already quoted - you know it makes sense...
