Paguro 4000 high no load voltage
aerobat
6 Apr 2025
Germany
Hallo gents !
I Just realized my paguro 4000 ( starts and runs very fine , no issues) puts out 258 volts no load . Shore power is 235-240.
Can i adjust this somewhere ? A bit nervous to plug in sensitive stuff on this .
Thank you much for hints !
I have the slightly larger 5.5 on my boat and the manual suggests the following:
I'm not actually on the boat at the moment so I can't physically check where the adjustment is and the manual doesn't tell you. The engine speed is shown on the LCD display on the remote.
I assume when they talk about capacitor they mean the field capacitor on the alternator as I don't think little generators like this have AVRs
I think i have the older style remote with diodes indication for load and oil press / overtemp shutdown , no rpm indication so i have to figure out how to check .
is the field capacitor connected to the starter battery ? The manual / wiring seems to indicate this .
Thanks so far !
Thanks so far !
Oh, sorry, I read 4000 and assumed 4 SY, mine is 5.5 SY. In my manual it shows it connected to the alternator by two green wires.
This post has a bunch of other manuals which the poster says are generic ones for similar generators: Paguro 4000 generator won't start
Hallo gents !
I would switch on a non sensitive heavier load first such as a heater or kettle. That will soon get the voltage down to a more sensible level. Then once stable let the electronics turn on such as the battery charger or TV.
