simonfraser
Hi, the easiest - but possibly not the best ??? - way to fix the lower whisker for my spi pole would be to fit a pad eye to the lower part of the bow
the bow is made of at least 50mm deep / wide laminated cedar epoxy coated
the whole boat weighs 1200kg, sail area would indicate a max load of 500 kg
so, use a pad eye and two hefty self tapping scews ? sizes ?
bolt through would of course be best, but there is a water tight compartment at the bow, but no access hole, unless i go above the bunk floor in which case the angles are very poor
alternatively i could have a U shaped fixing made with an eye on the front
fix the U by screwing into the side of it, screw sizes ?
sugestions please, many thanks
