JonnieFlamingo
The planking on Flamingo is pitch pine screwed to oak frames with 2" #12 bronze screws. Where I am replacing frames I am also replacing the screws, and apart from recovering from the eye watering price of said screws, I am now worrying that some of the existing holes are damaged too deep and oversized, to the point where the screws will be in danger of pulling through. Is it acceptable or good practice to drill out the holes with an oversize hole bit and then epoxy in a grain plug that can then be drilled and counter bored to the correct size? Or should I rout out a larger patch as has been done previously on the hull?
Jonnie
Jonnie
