8916
Many thanks to all who replied to my engine heating problem. Someone asked for more information, so here it is,
Merc. 4cylinder engine with integral water pump which is expected to circulate the fresh water round the keel cooling system. This is a lot more work than with a heat exchanger. I have read that these pumps are not up to the job! There is a header tank which has one pipe only comming out, there is no filler cap ie. 7lb. rad cap.
The keel cooler is outside the hull. Sea water is only used for exhaust cooling were it leaves the manifold,so the engine relies on fresh water cooling entirely. My feeling is thet the header tank needs an inlet and outlet pipe and a pressure cap fitted which I intend to do asap I have a problem trying to understand the thinking behind the original design. The water is getting round the circuit but not quickly enough . Each engine is independant of the other. Colin
