sjchilde
New Member
Hi,
I have recently bought a secondhand Honda 4 stroke 2 cylinder outboard. I haven't used it on the boat yet, just in a bin of water. It starts and runs well but I was concerned there was hardly any water from the tell-tale.
I have separated the lower leg and I found the impeller was new, and the gaskets. I was able to blow through the pipe up into the engine so I don't think there is a blockage there. Then I noticed the shaft seal under the impeller was not pushed down properly, so it was blocking the cut out where the water finds its way into the impeller. I have pushed the seal down to where it seats properly. This didn't solve the problem.
There is plenty of water coming up the pipe that comes out near the oil filler and goes into the manifold. So I have now removed the manifold. It was quite nice and clean and although the thermostat was stuck open I didn't find any problem. I replaced the thermostat with one that works and ran the engine for a while. It had a reasonable flow from the tell tale for a while, then it stopped and the engine got hotter and hotter until it stopped. (I kept turning it over so it didn't seize.)
I am guessing there is a blockage somewhere but I can't think where. Does anyone have a diagram of the water flow in this engine? What is the role of the venturi (orifice) in the water pipe going into the inlet? Is it possible for the thermostat to sit in an airlock and not open? These engines have been about for thirty years, someone must know!!
Many thanks for your help!
Steve
Steve
