Csprod
New Member
OVERHEATING ??
Hi,
I own a small raw water cooled diesel engine (BUKH DV8) and am (potentially) having a few overheating problems...
The main symptom I have is after running under load, the engine FEELS HOT and SMELLS HOT. Its too hot to touch, and has a smell thats hard to explain, but that i tend to associate with an overheating engine (entirely unscientific i know!).
Troubleshooting so far.....
1) Water flow at the exhaust (and anti-syphon tell tale) seems OK.
2) The temp alarm never sounds (its set at 80C/170F i think).
3) I wired up a temp gauge (from the same probe in the thermostat housing) and it cycles between about 50C/120F and 70C/160F
4) Checked the thermostat, it opens at 70C/160F
5) Checked the impeller - it was OK
6) Checked raw water inlet - no blockages
7) Checked the flow of the water through the pump - good throughput.
Am I dreaming or is it possible to have the engine overheating, but for it not to show on the water temp gauge (in the thermostat housing) ?
What to check next ??
Thanks,
Craig.
Hi,
Thanks,
Craig.
