Lakesailor
My bro-inlaw bought a little cuddy boat with an outboard. It ran well enough in a dustbin for 5 minutes or so, but when we took it on Ullswater the tell-tale stream became very hot and I don't think it was chucking any water out of the exhaust below the cavitation plate.
Looking at the motor the thermostat housing has obviously been off and investigation showed no thermostat in there. There are also signs of overheating around the plugs.
He's going to take it to a dealer in Penrith, but do the forumites have any idea why it would be overheating? Just as a double-check on what he gets told, really.
The tell-tale stream is strong so I assume the impellor is OK. There is no thermostat, so there can't be a closed system there. Are any other blockages possible? Could the leg be too short? The cavitation plate does lie parrallel to the bottom of the transom. We thought of taking a couple of inches off the transom recess.
It's a 1981 long shaft 8HP 2 stroke.
Starts first pull.
Starts first pull.
