Adams10
We have recently replaced our 20 year old Drofin diesel auxiliary on our Adams 10 yacht with a Beta Marine 20hp Kubota. We have also fitted a new geared two blade folding propellor. The Adams 10 is a cruising version of a 33ft "in shore" racing yacht which has a relatively light displacement, narrow beam and fin keel.
The engine is rated at 20hp at 3600 rpm and has a 2 to 1 gear ratio.
We have found that we can only get 2700 rpm out of the motor under load in flat water. The motor will run indefinitely at 2200rpm but when we push it at the maximum speed of 2700 rpm for 20 minutes the temperature warning light and buzzer come on. We have a 3/4" water inlet and have removed the strainer but the problem persists. Is it likely the overheating is due to propellor mismatch.
