Conachair
I have a Bukh 20 onboard, raw water cooled. I've had a lot of overheating problems. First time i thought it was the thermostat so I just took it out. Seemed to do the trick but then it overheated again (alarm goes off - about 94 deg I think). Temp guage not working so I keep an eye on the temp using a multimeter measuring ohms across the temp sensor, alarm sensor goes back to panel as normal. I put the sensor in a pan of water and slowly brought it to the boil with a digital thermometer making a note of the temp and ohms along the way. Seems to read slightly differently with engine on but I think it's pretty accurate. Now I have the pipe going from the Y split to the thermostat housing blocked so that all the water from the impellor goes through the engine which seems to work, runs about 50 deg C. Impellor seems fine. Before blocking that pipe the problem was intermittent, some days would be fine, very stable, anotherday it ran cool for a while, shot up to about 70 then back down again after, say, 20 mins. Engine was built in 1983. I attached mains water to the water input into the engine and ran it for a while with the output into a bucket to catch and crude, some what looked like sand came out with other bits of debris.
Any ideas? Problems occured between north of spain and portugal so sea temp pretty constant. (about 16/17 deg C if ST40 readout is to be believed.)
TIA
Padz - Conachair
TIA
Padz - Conachair
