steve157
Active Member
Hi, am having big problems with one of the engines as it keeps overheating and have now run out of ideas if anyone can help it would be great.
Symptoms are the engine will idle all day but as soon as the revs build under way the engine overheats. Have had a look at the impeller which looks ok and there is flow being exhausted out of the leg. I thought it might be the thermostats so changed these still no better. Thought it might be a air lock as have changed the calorifier but the flow and return pipes are hot and the water is heating up so am completely stuffed.
Do you think I should bypass the hot water tank to eliminate that just in case as that's the only thing Ive done lately.
