MedDreamer
- Joined
- 10 Sep 2002
- Messages
- 3,651
Some of you will recall that last year the same part (upper section) of my mercruiser Alpha Gen 2 leg failed on two occassions. According to the company that carried out the repairs the second failure was due to a faulty part provided by Mercruiser. This may be true, and it appears Mercruiser did replace the part FOC, but I still feel that the same part failing twice is more than co-incidence and that the root cause has still not been determined.
In the near future I will be having my boat lifted for antifouling etc. and I am going to ask the company who are doing this (not the same people who carried out the repairs) to check the outdrive installation.
However what should I ask them to look out for? Could it be an alignment issue? I know that they need to ensure the lubricant has been added correctly (ie bottom up) but i am pretty sure this wasn't the issue as I was there when the leg was dismantled after the last failure. Are there any other things I should be asking them to confirm.
Also the Mercruiser drive has a dog clutch which crashes into gear with serious crunching sounds sometimes, can this damage the teeth? and could this result in the failure
Any suggestions would be appreciated.
Martyn
Martyn
