seumask
Another Outboard question.
I have a fairly ancient Yamaha 8 that starts fine and idles normally to start with. However as soon as it's used for a couple of minutes it wont run at low revs, cutting out and will only then start with the throttle fully open if at all.
I have checked the fuel supply and made sure there is no water in the fuel by emptying the tank.
I have had the Carb off and appart none of the jets appeared blocked.
Does the considerable knowledge of the forum have any further suggestions as to what I might do to fix this issue. I suspect something more complex has gone wrong but don't know where to look?
