Outboard woes
surekandoo
23 Feb 2002
Home:Nottinghamshire Boat: Blackwater Marina, Esse
Just got my Suzuki DT4 out of winter storage, given it a service, changed water pump impellor etc.
On test running in a tank, I don't get any flow from the tell tale.
I've tried all the usual tricks, fresh water up the tell tale under pressure - this drained OK from the leg. Fresh water up the pump exit pipe - also drained OK with small dribble from tell tale. Checked pump - electric drill on main shaft - pump healthy.
Sounds like a blocked internal water way despite unit having been throughly flushed with fresh water at end of last season.
Anyone got any solutions or ideas or is it the big strip down?
dickh
8 Feb 2002
Suffolk
Have you reassembled the impellor correctly with all the bits in right place? This happened to me many years ago and it was only discovered when I took it to the dealer to fix it.
Sui Generis
27 Nov 2004
Cornwall
Had the same trouble with mine and it turned out that the waterway round the head/block was full of salt and corrosion and blocked. Cleaned all that out and AOK for a few years.
Second time it happened same problem. However, I haven't since then been able to source an new head gasket, so if you find one let me know where from and it may yet run again!
steve28
19 May 2003
Cornwall
www.falmouthgypsy.com
you might get some joy using an inner wire from a bike brake cable up the tube, this worked for me in a couple of instances. I now use the marine descaller and this keeps it flowing nicely. you might find it will unblock it if you can get enough into the block.
steve
William_H
28 Jul 2003
West Australia
You said that puting fresh water hose on the pump outlet pipe gives small dribble at the tell tale. My Johnson does the same thing periodically. a piece of wire I use 3/16 1x19 pushed up the pipe seems to clear the obstruction. I think you should get a vigorous tell tale flow with a garden hose attached in place of the pump. good luck olewill
impact30
4 Apr 2005
Limerick Ireland
Milking Machine descaler worked well on my yamaha and should be readily available, however I can't tell you yet first hand of any long term side effects. As far as I know it contains phosphoric acid. I turned it upside down and fed a solution into the telltale outlet and let it work for about 5 minutes, then flushed with fresh water.
surekandoo
23 Feb 2002
Thanks everyone. SUCCESS!
Used kettle descaler (citric acid) with hot water. Checked pump assembly - it's OK - will only go back together correctly. Broggled the telltale out with bowden cable as suggested. Discover alternative access to waterjacket under cylinder jacket & gave that a blast too. It all worked and I have a healthy dribble now.
But my woes continue - damaged trailer on way down to launch and erected mast but forgot wind vane. Do you think I should stop sailing in view of these contraindications? ;-)
Joe_Cole
14 Feb 2002
I think that you've also successfully coined a new verb, "To broggle".
Brilliant, it seems to describe it perfectly! I shall use it myself at every opportunity. /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif
I suppose that someone will now come in and say that they've been using the word for years!
