born2sail61
as part of my refit/project,i'm having to rebuild the engine well. It's been butchered at some point in the boats 51 yr history.badly. I have 2 questions,i hope you can answer. Firstly,how far below the bottom of the hull should the prop sit? Which leads nicely onto q2, what are the relative lengths of outboard engines,long,standard and short shaft? I'm guessing there will be slight variations between different makers,so an average for each length would suffice.i'll probably end uop with a seagull due to financial constraints! Thanks
