Frank mellin
I am trying to set up my evinrude 14hp engine but couple of queries.
When i try to run engine in test tank no tell tale water coming out.
What level does water need to be at to work.
I was told that engine should sit with cavitation plate just skimming water.
You will se from pic that the water inlets are above the plate so cant see how that will work.
Should water level be higher in order to pump water
Youve probably guessed from this that my knowledge of outboards is very limited so apologies for my ignorance but some expert guidance would be appreciated.
