Outboard tilt rod material
Durcott
10 Jul 2006
East Cowes, Isle of Wight
Hi folks,
just a quick one - I hope.
My old Honda BF9.9a outboard is missing its tilt adjustment rod. It's basically a 10mm round bar.
I plan to make one with a bit of stainless threaded rod and a couple of nuts, but I have an alarm bell going off about aluminium next to steel in salt water :eek:.
I THINK stainless steel will be OK inside the aluminium transom bracket castings, but I'm not 100% sure of my chemistry.
Can anyone advise before I take the plunge?
Jeff
Personally I would prefer to use a smooth rod rather than a threaded one because there is less surface area exposed. If you are really worried about the interaction you have the option of giving the rod a thick coating of paint. Alternatively you could slip the exposed part of the rod (between the nuts) into a short length of plastic tube.
The tilt pin on my Evinrude was painted steel.
I have replaced it with stainless steel... no problems
But Puff the MD's advice is good . Use plain round bar threaded only on the ends for the nuts.
But Puff the MG's advice is good . Use plain round bar threaded only on the ends for the nuts.
A few years ago my son dropped the tilt rod from our Yamaha Malta, I couldnt get a replacement immediatly. He wanted to use the dinghy so had a mooch around the bins at the marina, found an oven shelf. A hacksaw and a pair of molegrips and a new tilt rod was born.
I saw the engine on eBay earlier this year, its 10 years since this happened and its still going strong. So no, I wouldnt worry about it.
Hi folks,
Jeff
Let me have a look in the shed first, I have a load of spares for that engine...
If it's the same as the one in the pic, PM me your address and I'll stick it in the post.
