scozzy
Hi all
Maybe a silly query but a riddle for me at least...hoping for help!
So Ive got a mercury mariner 4hp 2stroke circa late 90's outboard i use as a tender/trolling of my little bilge keeler.Had it in the bucket to flush etc (another story!) and whilst engaging gears to give it a good run through i noticed no "swirling" in the water when in gear.........on inspection when in gear the prop shaft holds as it should although the prop itself spins freely any old way and as such wasnt engaged with the shaft under load or any old time!? My assumption is a lock nut/grub screw type of thing must be sitting on the the harbour floor somewhere? For reference the prop shaft just has a bullet shaped end with a split pin and prop sits in place with no visible means of support besides its sleeve,not the bolt and spindle arrangement that im guessing would be easier to solve!
In any case any helpful tips or hints much appreciated,be nice to think i dont need to replace the whole unit,no damage from any adventures to report as a symptom!
Cheers
L
Cheers
L
