dylanwinter
the instructions for the Tohatsu 6hp sail drive call for the oil in the lower leg to be replaced once a year
it tells you to remove both plugs - drain it all out and then replenish it from the bottom up
you are supposed to squirt oil upwards through the lower filler until it emerges from the top and then screw the lower plug in without spilling any
what is the engineering sense in this?
Dylan
Dylan
