wilsonmark
New Member
I am sure in not alone in needing to clamp my outboard in a fore and aft position and then steer with the tiller. However the friction screw on my 2.5 Yamaha swivel bracket can't really be tightened enough and the engine slowly rotates during use - v annoying. A larger Mercury 5hp did seem to be clamped but then the friction screw just sheared off when I was starting it!
Does anyone have any experience of this or how to get around the problem. The engine dealer says those friction screws are not designed to lock the swivel bracket only tighten the action - so what can you do if you do need to lock it?
